Hi All, I'm new to this sort of thing but here goes. Please if anyone could shed any light on what the following could be I will be very greatful; I have a Toyota Hilux 3ltr 07plate, it was involed in a hit & run on a round-about with a Ford Transit Flat-bed in October, yes he did a runner. My insurance fixed my Hilux, but on getting it back from the garage within days it developed a metal clunking sound that could and still is being heard when turning full lock left in forward + reverse. I contacted my insurance company and my Hilux has been back to the garage were I test drove it for thier head engineer, he confirmed that he could also hear the clunk. It has since been test driven & looked at by an Independent Assessor and Toyota + a full safety check carried out, they also heard the sound but thier findings were inconclusive. The safety check only showed that my front breaks + discs needed repalcing, so I have had this done and also fitted a full set of new tyres. The clunk is still there! The insurance company now would like the truck to go into Toyota for a three hour strip down starting with the front passenger side wheel and working back. If this also comes back as be inconclusive or not part of the accident then I will have to pick up the cost of just under £400, OUCH! . Any idears are wellcome. THX.
Sounds like the protective covers have come of the "bump stops" there are 2 on each front wheel, and only make contact on full lock. It's a common problem with Hilux's.. Use spray grease, on all four should stop it .
I have to do mine every 4-6 months
