Land Crusier Battery Discharge
hobbsyathome
Help!! my land crusier battey keeps discharging i have had the batterys and alternater tested they are all fine,if i dissconect the Battery and then reconnect it starts fine but if i dont after an hour or to the batts are completley flat any ideas? thanks
hi matey
it looks like the (+) is destroyed inside.
yes the symptoms are the same -- alternator is in order as well as greed full charge indicator is visible on the Battery lid but after an hour or less you can not start the engine. -- i have had the same and was forced to change Battery. i ppresume your Battery is around 3 years old -- correct ? the sort cut is inside mate. Have it changed. I do not believe you have an electricity lose.
But due to short of information we are disable to understand whether or not it is diesel powered ---- and in case glow plugs relay is faulty -- this might keep glow plugs be in ON and discharge the battery. Cheers/Igor
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
