N/s Power Window U/s!
Aeroman1
The n/s power window winder on my wife's 2004 T3 has suddenly stopped working. The driver's side is fine and I wondered if the recent cold weather had trapped the window and blown a fuse. I have tried making sense of the two fuse box diagrams but failed! Can someone tell me if the power winders are separately fused and where I can find the fuses? Inside the car there is a box with a 30A fuse marked "POWER" but if this is the only one then the fuse must be ok for the o/s winder to work.
Have you by any chance hit the button on the drivers door which disables the passenger window ?
It is a common error.
Thanks - spot on! Neither of us uses this facility and the button must have been accidentally pressed. It stays down and stops the n/s power winder working.
Very relieved and equally pleased to report that the little Yaris continues to deliver
excellent reliability!
