Hey, im new here, I have a 93 Corolla that has about 155,000 miles on it. Lately when I am driving, not when I accelerate, but when it is coasting with my foot off the pedal there is this faint squeaky noise that sounds like it is coming from under the driver side door almost. I can't tell if it's been doing it for a while or not, could this be a lot of things or any ideas/suggestions? Thanks
Welcome to TOC. :thumbsup:
Have you checked the exhuast fixings? Might be that it's loose & you don't hear it when you are accelerating so it shows up more when you're coasting?
If it resembles the sound of nails on a chalkboard, you might want to check your brake pads.... the wear indicators could be starting to make noise, indicating it needing a replacement.
