Just a little tip here sorry if someone else has posted anything like it.
When I got my Lucida recently, the 6 vents in the roof serving the mid/rear passengers had most of the vents all loose and falling out, the clips had broken off the vents themselves, but the pegs on the main part were OK.
I saw price from £30 (secondhand) to £50 (new) for a set of three in their housing.
Being a tight wad I had some old failed CD-R's (beermats as I call them) I cut them up to sort of rectangular shapes and evo-stick'd them to the side of the vent, drilled a 6.5mm hole for the pegs to go in chamfered the edges to allow the peg to slide into the holes and all is fine again :group-cuddles:
Hi
I have just bought a Lucida and 5 out of the 6 vents are missing, can you let me know where you got a price of £30 for secondhand replacements.
Paul
http://www.bbcspares.co.uk
Ive not tried him or anything so I can't vouch for anything he sells, maybe someone else has here
Thank you
I have checked his website and will give him a go... will let you know how I get on.
Cheers
It must be a thing with this model, most of mine are lose or fall out or missing, thanks for the advice, I've got plenty of coasters ! I'll give it a try !
Even if only one side is broken, its best to do both sides with the mod as I did only one side at first but the vent was still floppy
