Timing Belt
Charlie3254
I need advice please re my Avensis D4D TX3 which is due for an NCT (MOT) soon, would I need to change the timing belt , or take a chance in letting it go through the NCT as I hope to sell it in the coming months. it has 70, 000 miles on the clock .
Cheers, just found out its chain driven, and if it's not noisy it should be ok for the NCT (MOT)
Thats a load of your mind Charlie.
Thats one of the main reasons i got an Auris cos it has a chain.
I hope to purchased an Auris Automatic in the coming months, what do you think of yours. Charlie
The cabin trim is very poor,but mine an 07 reg and later models have improved on this point so i am told.
engine,brakes steering etc all fine.car is very quiet compared to my earlier cars that were diesels,which what you would expect.
Not very keen on some of the positions of controls like the cruise and buttons for information display,also no clock seperate from the display.
my model is smart start and smart entry.i cant open boot independent of unlocking the doors,though some models you can. it also hs whats called optitron gauges i would sooner have normal type fuel gauge and temp gauge,
there is no oil pressure warning light as is normal when you turn on ignition but if you have a oil pressure problems then a warning message appears.well it supposed to what happens if something goes wrong with this warning system, you cant test it out. It maybe a fail safe system.
But there are more pluses than minus to be fair.
Not the best Build Quality car ive owned. but as said later models are supposed to have improved.
All being well,i hope it will be my last car as at my age i will have to hang up the keys in not many years time.
Would i recommend an Auris,well i would have good look at the opposition first.
Thanks for the infrormation, I will check out other reviews on 2009-10 Auris cars before I purchase. Regards Charlie
