Very Amusing And Quick Read....
Fizz
Im not usually one for reading these.. but this was very good.. :thumbsup:
After every flight, pilots fill out a form called a gripe sheet,
which
conveys to the mechanics problems encountered with the aircraft
during
the flight that need repair or correction.
The mechanics read and correct
the problem, & then respond in writing on the lower half of the form
what remedial action was taken, & the pilot reviews the gripe sheets
before the next flight.
Never let it be said that ground crews & engineers lack a sense of
humour. Here are some actual logged maintenance complaints &
problems
as submitted by Qantas pilots and the solution recorded by
maintenance
engineers. By the way, Qantas is the only major airline that has
never
had an accident.
> > (P = The problem logged by the pilot.) (S = The solution and action
> > taken by the engineers.)
> > P: Left inside main tyre almost needs replacement.
> > S: Almost replaced left inside main tyre.
> > P: Test flight OK, except auto-land very rough.
> > S: Auto-land not installed on this aircraft.
> > P: Something loose in cockpit.
> > S: Something tightened in cockpit.
> > P: Dead bugs on windshield.
> > S: Live bugs on back-order.
> > P: Autopilot in altitude-hold mode produces a
> > 200 feet per minute descent.
> > S: Cannot reproduce problem on ground.
> > P: Evidence of leak on right main landing gear.
> > S: Evidence removed.
> > P: DME volume unbelievably loud.
> > S: DME volume set to more believable level.
> > P: Friction locks cause throttle levers to stick.
> > S: That's what they're there for.
> > P: IFF inoperative.
> > S: IFF always inoperative in OFF mode.
> > P: Suspected crack in windshield.
> > S: Suspect you're right.
> > P: Number 3 engine missing.
> > S: Engine found on right wing after brief search.
> > P: Aircraft handles funny.
> > S: Aircraft warned to straighten up, fly right, & be serious.
> > P: Target radar hums.
> > S: Reprogrammed target radar with lyrics.
> > P: Mouse in cockpit.
> > S: Cat installed.
> > P: Noise coming from under instrument panel. Sounds like
> > a midget pounding on something with a hammer.
> > S: Took hammer away from midget.
:D :D
Rash
t'is quality, sometimes reality really is scarier than fiction!!!!
And you say quantas have a good safety record, I would hate to see some of the other opertators!
Think I've just entered a Time Warp...that list was doing the E-mail box tours, years ago. Very good though!
