Reversing Light Wires
Robertm
:huh: Hi, just fitted reversing sensors to my mums 2002 Yaris, but need to know which wires in the rear light cluster to connect to for a live and earth feed for the reversing light.
Many thanks,
Rob
Just take out the cluster. I think the UK have a hard wired circuit and it's common sense. Just take a soldering iron and solder off a wire to tap to your sensors. Earth can be taken anywhere fromt the car chassis.
Are you sensors in the bumper? If so, where did you feed the cable into the car itself? Going to fit some to mine tomorrow!
Al.
Al.
I've already wired them up and they work fine as long as the lights aren't on, (in which case they don't work at all, so I've obviously got a wrong connection somewhere!).
The sensors were a surface mount kit, but I made up some brakets and attached them to the bolts on the lower edge of the rear bumper where there are already 2 bolts going through.
The cost of the kit was £50 or so. Let me know if you want any more details.
I haven't removed the cluster yet as I was hoping someone may just know which colour wires I need to connect to. If not, I'll remove the cluster as suggested.
Cheers,
Rob
Edited to add that I fed the wires in to the car via the bung in the bottom of the spare wheel well and then sealed it again with hot melt glue.
Rob
Any chance of some photos as to how you fitted the sensors please?
Cheers
Rob
Cheers
I made a couple of right angle brackets in which I drilled a hole and mounted on the two bolts which are already on the lower edge of the rear bumper. The sensors themselves were self adhesive, so I just stuck them to the brackets.
I've just taken a picture which I'll try and load up.
The install is pretty discreet and probably wouldn't be noticed unless you're actually looking for it.
The kit was assessed by Auto Express and won their prize for best performance verus cost (appx £50 as I've already mentioned).
I fitted a similar kit to my Discovery 3 years ago and it cost almost £300, so this was a bargain and it works a treat!
Rob
how did you run the cable into the car? Is there a grommet that you can utilise? I'm gonna install the flush drill in type.
The rear cluster is only 2x 10mm bolts. Takes 1 minute to remove!
Al.
Al.
I ran the cables along the inside rear edge of the bumper, (held in place with cable clips), and then ran them out to the gromit in the base of the spare wheel well.
I made a small cut in the gromit with a stanley knife, pushed the cables through and then sealed it again with hot melt glue.
Let me know if you ned any other details.
Rob
