Radio Install
markgm
Hello,
I have a ST202 Jap import celica late 94, changing the radio, can anyone tell me what the wiring on the two plugs corresponds with ? :ffs:
Hey it's an uphill battle getting any info outta people for that stuff i've tried. the best option is to get a hold of a test light thats always done the trick for me. then again i gave up on my latest celica cos its one of those 10 speaker live sound system setups, factory amp, 4 tweeters, 2x 5-1/2's, 2x 6-1/2's and a couple of 8" woofers in the doors. if you have one of these good luck to you, they will suck your patience dry. but yeah if not a test light usually gets u powered up and the Speakers is usually a process of elimination.
audioleads do an iso wiring harness for the toyota active speaker system .
You can get it from Halfords and it plugs into the original wiring loom and then into the iso plug on your new stereo.
I got one for my mr2, the part no is pc9-406 but i dont know if its the same for the celica.
12-15 quid for non active plug or 32 quid for active.
