Poor Mpg
Drift taxi
Hi have 57 plat 2.0 d4d and my fuel consumption seems a bit poor it's been recently serviced and I had the egr valve cleaned out and it's only done done 60k I have tryed v power and injector cleaner and am running out of ideas any help would be appreciated
Paul
Was the fuel filter changed? I use a K&N air that helps with mpg. The cold weather makes a hit on fuel use... What psi are you running the boots on? Try 36psi all round
What do you call bad? During colder weather I only average 42 to 44 mpg with virtually no urban driving.
i am only getting 30 around town now i only work 3 mile away running a 2.2 d4dtr eatate itsdone 55000 but only 8000 after a new head and injectors its in mr t next week i may ask them about the mpg
steve
Same as the others how bad is bad and whats the vehicle usage?
With my 2.0D4d I would expect approx 35mpg in town assuming a 5 mile journey each way, drop it a bit for winter when heater/lights etc are needed and slightly more for summer
Also would depend on how well, mechanically, the car is looked after
The car has no chance of getting even slightly warm after 3 miles, so I would expect a poor MPG. I think if you worked out an average when the car was warmed up and on a run it would be far better. These diesels take an age to warm up
Kingo :thumbsup:
+1 with Parts-King - 3 miles just isn't enough for these engines to warm up.
for those types of journey you would be better with petrol (btw did any one else read the article in The Sunday Times Ingear section yesterday re. running costs of diesels v petrol for average users?).
