hi one of my rear wheel bearings has started to rumble on my carina e how do i remove the hub with the bearing in to to change the bearing its self is it an easy or hard job to do
cheers
steve
Hello Steve
Take off the brake drum and ull see 4 bolts behind the flange. Undo those four bolts and the complete hub will come of. Its quite easy
Hi Steve, you can take the bolts in there.
