Loud Humming Sound
obomz
I have a toyota avensis 2007 model which just out of the blues just started making a loud humming sound.
i have been to my local toyota dealer and they suspected that due to low ATF that it would make noise but that if i fill it then it would stop. But till now its still humming.
Could be the air filter box thats doing it! There is a mod for that... Or a wheel bearing on its way out! But I'd be looking at the air filter box 1st...
Thanks for your response. Please i'd like to know what exactly to check for in my air filter.
Also i went in for a check up on my gearbox today and actually found out that my level was low and had to pur in one litre before the level checked out okay but the hum remained! I was told that if i drive it around a bit that it should stop the humming but till now alost 8 hours after its still humming!
Also how do i check my bearings?
Thanks a mil
hi matey
when typed - you have to understand we can relay on those info from first hands and in case you do not give it in details then it is so hard to advice.
But what did you exactly think as --- loud humming sound.--- ??
First thing to do is to open a bonnet when engine is running as idle and visually check -- may be something has to be re-tighted such us an air filter housing or like this?? Try to send even youtube file right here when bonnet is open.
I presume a loud humming sound might be originated from another issue. Please revert and this will help to all of us and save yr time . Cheers/Igor
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
