Fitting 18" Wheels
mad midge
Has anyone fit 18s to there car with 30mm lowering. If so what size wheels and offset did you go for.
Also do you have any pictures.
Thanks.
No problem mate :)
No rubbing at all. But I've been experiencing some clearance problems at winter when there's lots of snow under the car. It is not dangerous though and happens even for cars without lowering springs. Just not as often as when you've got lowered car.
No a single ground contact though so I feel myself quite safe. Don't need to worry all the time if the car will clear the speed bump or not. Of course I try and drive carefully and slow to stay on the safe side as it's not a jeep :)
