Centre Bore And Offset!
mad midge
What centre bore does the auris have and what range of offset can you use. Looking at some wheels that have a centre bore of 74.5 and offset et45.
With respect You wont get an answer of anybody unless you mention your cars year, model type etc otherwise its guess work...
And what's going to be your rim width? Without knowing that, it's hard to guess the proper offset.
Think ive worded this wrong. What i need to kno is what size centre bore do i need? So i can get the correct spigot rings.
And was wondering if i need a certain offset to clear brakes etc.
The wheels im looking at are 18x8 et45 with centre bore 73.1.
Centre bore is 60.1. Go for ET40 or even 38, especially at the rear, if you're looking at some 8" wide rims :) Will bring your wheels nicely out of the wheel arches. The rear ones are a bit more in, so need a bit smaller ET to bring them more out compared to the front. See my car's introduction thread (allready linked in another thread) and you will see what I mean. Check out the first two shots taken from the side.
