Yaris Power Window Problem - Fuse Blows!
Catanha
Need some help, please!
Everytime I try to open a passenger side window from driver's side console it starts going down but fuse blows (pink one - 30A)! :(On the other side, everything works fine when opening and closing passenger side window using the passenger side switch :huh:
It's 2004 Yaris (5 door, LHD).Thanks in advance, I would appreciate any help on this matter.
P.S. Sorry if I made some writing mistakes - it's been a while since I wrote in english... ;)
Sounds like a wiring fault: maybe the wires to the window have broken insulation which allows it to short...You need to test with a multimeter..
Are the rear windows power operated on a 5 door or not? If it's only affecting the front window perhaps the window mechanism has siezed or broken, leading to an overload on the circuit
This was my first assumption and in that case an electrician will have to take a look and fix it.Thanks!
No, only front windows are electric...Surely something causes a circuit overload and I'll probably leave it to an electrician to remove the both door panels and thoroughly check window mechanism and all connectors and wires.Thank you!
