Brake Fluid - Quantity
sushd
When replacing, what is the quantity needed? Couldn't find it in the owner's manual.
Anyone knows?
Hi as far as i know you change the fluid untill it runs clean and free of bubbles about 1 litre I should think.
Do you need access to the Techstream software to change the brake fluid, or is there another way to do it?
I have serviced and changed brake pads, and flushing brake fluid is a job I would like to do at some time.
IIRC you just have to make sure the pedal is up to pressure before turning the ign on, then you wont get any fault codes.
Personally I would disconnect the 12v Battery whilst doing it.
