Side Steps "l" Shape Bracket Size
bluebones
I have brought some side steps for the missus 04 plate 5 door rav4, but surprise surprise the L shape bracket that mounts to the inner seal is missing, and the seller has gone all quiet.
Plan is to make my own so if someone can be so kind and give me the sizes for the bracket, have looked into it a bit and the length of if i think is 1450mm so just need hight & width.
thanks inadvance.
Hi George,I also had this problem and after help from Big Kev I purchased 3 metres of angle iron 3x3 cm x3 mm thick.
HTH
Del
HTH
Del
thanks derek, just the info i was after :D
If it helps further, I will measure the bracket on my side steps when I get back to Spain, but that won't be for 2 weeks.
HTH
Del
No probs,matie.
Just an afterthought,I was wondering if you had the thin rubber pads on the feet that press against the underside of the floor and also you will find you need packing under the centre bolt.
Del
thanks for the offer ainsley, but hoping to have them on by then.
HTH
Del
No probs,matie.
Del
the rubber pads are stil on the brackets,but more info on this centre bolt please buddy?
