Drivers Seat Sagging
jimtaxi
The drivers seat has sagged to the extent its now uncomfortable does anyone know can the seat squab be replaced on its own or do you have to buy a complete seat? Also is the job of replacing this item easy or does it give problems. Its a 2008 2.2 T3X
Thanks Taxijim
Hi,I also use mine as a taxi,I took the seat out and put some extra foam in the top of the seat squab but below the cover,at first it was a bit hard but settled to become more comfortable,my bolster has frayed through which makes it really look like a minicab I'm looking at changing it quite soon
  • 5 years later...
Does anyone know if the drivers seat (not upright back) base on my Carina II is a 'webbing' hammock OR thick foam on a solid/plate base?
My seat is like a 'pot hole' - :mellow: - and rock hard!!
Just thinking it might need removing and :-
A. Thick foam replaced... or
B. ReHanging the webbing/straps... ??
2sav
