Replacement Wheel Nuts
MikeLovinUK
I'm looking to replace the wheel nuts on my 57 Auris. It has standard alloy wheels and I am hoping that someone can tell me what size I would need. I've found some on eBay which are M12x1.50, can anyone advise if these would be the correct size?
Many thanks
Mike
How is the price did you see in eBay?I'm not quite sure about its size.
You are right about the size but make sure you buy flat seated ones. If you specify the car the sellers should be able to advice on the correct type and size.
