Noise From The Engine When Accelerating (Auris 1.4 D4D 2009)
AlexanderK
Hi everybody,
my car now rounded almost 100.000km and in the resent period I start hearing a very strange noise when accelerating. The noise is louder when the engine is cold, almost like a tractor. I suspect the turbine or a hole in the exhaust system. the last one was checked at the dealership and seemed to be ok(at least no leaks). However i do not entirely trust the dealer as the garanty goes off soon. is there aby special problems with the turbine in the 1.4 diesel, any ways to check if it is ok?
Hi everybody,
it seems you do have an over fueling effect due to an injectors wear down.
regards
