Avensis 03 Tail Light Bulb Replacement
Carl_P
Does anyone know if and what items of boot interior trim need to be removed to fit the left hand side rear bulb cluster? It is different to the right hand side and looks as though I may have to remove quite a bit of trim.
Also do the cluster retaining clips have to be squeezed inwards or somehow else?
Many thanks.
If your model is 2003 onwards there are apertures in the trim to access the lamp clusters. For the saloon the two retaining clips are squeezed outwards (up and down), for the hatchback they are squeezed inwards and the estate has two pairs pressed outwards.
Fitter
