Maintenance Schedule?
Raving Gunnar
Greetings! I Wonder if such a thing as maintenance schedule and associated check liste Are available anywhere. I mean the ones that the workshops use. My interest is in the 4.2 d4d model 2004.
Have you looked at these items above in the "Pinned" section....?
Sorry no, probably need to do some checking on this site..
I just bought the car, it currently has 105000 km on the clock. But I need to check from 90 k and on since that is the last proper stamped and signed entry in the service history. My plan was to build a detaileld maintenance plan and do the stuff myself from now on. Hecne the need for the check lists.Overe here the workshop hourly price is getting outrageous so it pays off doing this myself. I found one such check sheet in the car (this was for 45 k), and it details everything to be checked for given mileage stepwise 15 k km, seems like they print one sheet for each such step. Very useful.
90000km service onwards, i listed them in order
Replace engine oil and oil filter
Rotate tires
Visually inspect brake linings/drums and brake pads/discs
Additional Maintenance Items for Special Operating Conditions:
Driving While Towing
Tighten nuts and bolts on chassis
Driving in Desert or On Dirt Roads
Inspect ball joints and dust covers
Inspect drive shaft boots
Inspect engine air filter
Inspect steering linkage and boots
Re-torque drive shaft bolt (4WD)
Applicable Footnotes:
1) Reset the oil replacement reminder (“MAINT REQD”) light after replacing engine oil, if vehicle is equipped with this light.
Next one...
Rotate tires
Replace limited-slip differential oil, if equipped (4WD)
Replace spark plugs
Replace engine air filter
Replace cabin air filter (if equipped)
Inspect the following:
Automatic transmission fluid
Ball joints and dust covers
Brake lines and hoses
Brake linings/drums and brake pads/discs
Drive belts
Drive shaft boots
Engine coolant
Engine valve clearance
Exhaust pipes and mountings
Front differential oil
Fuel lines and connections, fuel tank band and fuel tank vapor vent system hoses
Fuel tank cap gasket
Manual transmission oil
Radiator, condenser and/or intercooler
Rear differential oil (except 2WD)
Steering gear box
Steering linkage and boots
Transfer case oil (4WD)
Replace differential oil
Replace rear differential oil, including limited-slip (except 2WD)
Replace transfer case oil (4WD)
Replace transmission fluid or oil
2) Required under the terms of the Emission Control Warranty.
3) Inspect thickness measurement and disc runout.
5) Initial inspection at 60,000 miles/72 months. Inspect every 15,000 miles/18 months thereafter.
Next one!....
Rotate tires
Hope this helps
Ouch that posted a lot messier than when i wrote it, if you can't understand it ill post some links instead, you basically need to do everything above the additional lines and obviously it depends on where you drive as to whether you meet any of them conditions.
edit: nevermind, cleaned it up a bit
