Indicator Flashing
conker
Hello Forum members,
Can I replace the flasher unit or relay so that my 2008 Avensis T Spirit will indicate 3 times like my Mondeo ST and works VW Caddy does when just pushing the switch up or down
Also I have a Black plastic microphone between the sunvisor and interior light switch, but when I try to find a phone via bluetooth nothing is visable? Do I need to go through the Sat Nav stereo to find it
Thank you for any advise with the above questions
Conker
Hello and welcome,
As far as I know, there isn't a flasher unit you can change, I've just got used to it over time
The microphone is part of a bigger phone system (hands free) that was probably installed when the car was new, I'm guessing then it was a company/lease car? But whatever it was, you should have a cradle for the phone (usually for an old nokia for example) This is all linked together and I doubt bluetooth will work with it; If you had the right phone you would slot it into the cradle, then when you got a phone you would put it on speaker, hence the microphone would be used in that instance
The only popular bluetooth system I know is of a company called Parrot. But exactly how it works I'm not sure ie I don't know if it comes with a similar hands free setup with a microphone and speaker
If your avensis flasher unit is anything like my Auris one then i think you will have a job replacing it with any other type.
on my Auris the flasher unit does not just have 3 or 4 wires going to it like older flasher units used to, but it has 8 wires.
its also very akward to get at,but then your Avensis may have more room.
Thank you for the replies regards the question.
Jas, there is nothing visible to place a phone in, or any holes where one might have been that’s why l thought it might be bluetooth.
There is an adaptor for iPod/iPhone charger in the glove box, but my iPhone does not work off it, just plays the music off the phone
Jas, there is nothing visible to place a phone in, or any holes where one might have been that’s why l thought it might be Bluetooth.
With the iPhone have you tried plugging it in and pressing CD on the head unit? The TNS 700 unit certainly works this way.
