Engine Oil
lasthope
doing oil change next week what is best oil thanks car is
toyoto avensis 1.8 petrol vvt-i year 2000 cheers
Use a 5w/30 Semi or Full Synthetic (Personally I would use a semi synthetic) Use a good branded make, not supermarket rubbish & obviously change the filter at the same time. 'Tis easy to do.
cheers lads might get all this
£14.70
Triple QX 5w30 Semi Synthetic Engine Oil (5 Litre)
4.49
STP ENGINE FLUSH for Petrol & Diesel - Oil Treatment - 450ml
3.06
Oil Filter TOYOTA AVENSIS Petrol 97 to 00
4.78
STP Oil Treatment Fluid 300ml for petrol engines add to oil additive
comes in at 27,quid from eBay
£14.70
4.49
3.06
4.78
comes in at 27,quid from ebay
Hi mate, I think the oil filter may not fit as '97-2000 Avensis engine isn't a vvti engine. Just an opinion but if your vvti isn't using a lot of oil and is running OK just change the oil and the oil and air filter, forget about the additives and spend what you save on a decent oil like Mobil or the great value and good Millers semi-synthetic oil.
Pete.
cheers mate just looked on eBay and its the right one,,,, 280744507622 and iam useing abit oil not much,
