Electronic Tuning Devices
Glasswarrior
Can anyone recommend an electronic tune-up device that is reasonably priced and actually works? I have a late 2003 2l D4D T Spirit Avensis and have read that it is capable of much better performance, torque and economy.
TIA
From reading other topics and other's experiences, it seems as though the cheap tuning boxes are not the best for an Avensis. The preferred method is going for a re-map, which I appreciate is more expensive, but if you're looking to keep the car for a long time then, its the option I would be personally looking at
Oh and the economy depends on how you drive afterwards :P
Cheap boxes should be avoided, like everything else in life, you get what you pay for, you cannot re-map a Toyota with a Denso pump, so the only way to go is with a tuning kit. We do them, priced at £375
Kingo :thumbsup:
Hi
I have sent you a PM on this, check your messages.
As Kingo says, avoid the cheapies I tried these with dire results.
Kingo :thumbsup:
Also look at the Tunit boxes that you can pick up on eBay for a song most of the time!...
