Hi
I have I Aygo Blue 2010 edition that I am currently trying to improve the interior light system for.
I have 2 extra interior light housings
1 front door switch
2 rear door switches
I need the following
2 intrior light connectors,
1 front door switch connector
1 screw for the front door switch
I have asked to local scrap yard if they had any aygo, 107 or c1 s in and no one seem to be crashing them down here :(
I then rang the local toyota parts guy and they said its part of the loom.
So down anyone have access to these parts or any other ideas?
I know I could use spades but i was hopeing to do it elegantly
Regards
PA
Hey mate, try this eBay link 140591296072. He's breaking a front end damaged 2010 Aygo Blue. You never know, he may have the parts you need.
When I added a switch to my wife's 3 door I used spade connectors. The screw for the front door is a separate part from the dealer which you should be able to get no problem. Not sure about rear doors though, sorry. Scott.
The front switch is available from Toyota, its the same as the drivers door, and is used on other Toyota models for years. The rear switches are unknow, but someone on the forum found a switch that fits (not Toyota). If you search the forum, you will find it.
And for the lights, I put a Ikea dioder on my Aygo. They are the best option in my opinion. They run at 12V.
http://www.ikea.com/gb/en/catalog/products/70119425/
I've installed Fridgedoor-switches on about 25 to 30 cars over the past years.
Found them at Conrad.nl but you might find a UK-based seller that has similar switches.
They need to be 19mm in diameter and have to be NC, so they OPEN as you push them...
http://www.conrad.nl...product/707210/
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
