02 Reg Puris O/s/f Widow Issues...
grey fergie
just fitted a window reg in the above
now when the widow goes up via the "one touch",
it goes up & then comes down again
i read about a "reset" ?
tried some suggestions to no avail !
can anyone tell me a idiots step by step guide before i pull my hair out !!!
thanks !
If it works manually (i.e. not auto), try lower the window to halfway down then press and hold window button all the way up and hold it for a further 2-3 seconds when it reaches the top.
tried whats been suggested, to no avail !
seems as if the glass is comeing up to far ?
dose'nt do it with no glass, although i've had it do it "off car" aswell ???
the motor will just spin until you stop it when its removed from the mec
theres no cycle as such (if that makes sense)
any help will be great as im loseing my hair !
and we now have a backlog of dead stuff to sort !!!
(6 to be exact !!!)
That is the reset method. Try holding for longer?
Diconnect the 12v auxillary Battery for thirty mins then retry programing method suggested above.
