Brake Light Bulb Fell In To The Lens
mikesimm
Hi - When replacing the brake light bulb, I twisted and pulled the bulb holder but the old bulb fell off inside the lens. Can any one help me with instructions on how to remove the lens so that I can access the old bulb which is ratting round. Thanks
It is best not to disturb the lens as they will be sealed to prevent water from getting in.
Your best option is to remove the rear light from the car and shake it until it drops out, easy job if you have a 10mm spanner or socket, remove the carpet from the boot to get proper access.
Maybe some wire with sticky tape on the end. Touch the bulb and it will stick to it.
