Fog Light Fault - Any Advice Very Much Appreciated
Hi there,
I have an issue with my fog lights.
When i switch on my headlights, my fog light automatically comes on and i have to push the button to switch it off. It has failed its NCT (National Car Test - Ireland )(MOT - UK) as a result.
Anybody have any ideas where to start looking. All other external lights are working, although the inner boot light is not working, could this be it?
Car is a 1996 Carina E TD Estate.
Any feedback greatly appreciated.
regards,
Chenzo.
Hi there dont know if you got this sorted yet, but mine recently developed the same, I was doing some re-wireing of the stereo and took off the centre console above to give me room, I saw the 3 switches above were filthy so I removed them and gave them a good clean, I put the 'fog' light switch back in and after a few days the phantom light came on and off evertime I flicked on the parking lights.
Scratch Head?
I noticed a few days later that what looked like part of the switch on the carpet, I removed the switch again and sure enough it was the sense resistor from the switch I did a quick fix with the solder gun since I could't find a scrap one at the time and it works great mostly, id say thats your issue, the sense resistor detects wheather the lights are in 'park' or dip/high beams, start with the switch this should be a cheap fix if not then its a problem with the light switch on the stalk, as far a wiring goes there fairly solid in these cars let me know if you get it fixed !
