Torue Settings
mhealy d4d
hi would any one have a list of torque settings for d4d 2 litre flywheel and camshafts
micheal
Hello mate,
I have attached 2 .pdf files which have the info you require, you will just need to scroll through them to find the info you need but it is in there.
You should have Adobe Acrobat Reader on your PC if not it is a free download from Adobe.
Regards Pete.
SERVICE SPECIFICATIONS.pdf
ENGINE REPAIR MANUAL.pdf
thanks pete
how do i take out the drivers side drive from the box
any help thanks
thanks pete
any help thanks
Hello again,
if you mean the drive shaft or gearbox here are more .pdf's for you.
good luck ... Pete.
MANUAL TRANSMISSION & TRANSAXLE.pdf
DRIVE SHAFT & PROPELLER SHAFT.pdf
Avensis clutch .pdf
