Tns 200 01-11 Release Not Working
avensis123
hi there
as you will all notice i am new to this forum. i recently bought a toyota avensis GS March 2002 model and i was given a cd named TNS 200 and for some strange reason it doesnt work. can anyone please point me in the right direction as to where i can purchase one or if anyone has one can they sell it or somthing.
thanks in advance
I hesitate asking, but ... the TNS 200 system uses a remote CD drive sited in the left of the bootspace - that is where you are putting the CD isn't it ?
The drive is covered with padded nylon material, slide the catch to one side to open the door IIRC.
Just in case ...
If you are already aware of all this, then I suggest your CD is damaged - was your purchase from a main dealer ? If so they ought to replace the CD.
Hope this helps.
There is a copy of TNS200 on Edonkey2000 Peer to Peer. (on and off)
http://www.emule-project.org
Search for ... TNS200, once emule is installed.
Use Nero? to burn CD - don't worry when you can't read the CD with your PC.
Whack it in the car and off you go.
HTH
