hi,
Over the past couple of weeks i have been driving my previa i hav noticed when i brake i here water moving about along the drivers side in the back of the car i was wondering if this has happend to anyone else and how they got rid of it
manny thanks!
Probably water sloshing around in sill.
Check the drain holes are clear - could take out a rear ashtray and look inside with a torch or remove trim to see.
there must be drain holes in there somewhere.
Or you can put clear panels on the side and get some goldfish :P
In my case I had it on a primera...but oddly the problem went after a couple of months.
There was evidence of a repair to the side and I figured (rightly or wrongly) that the sill had been damaged, possibly hammered in and a replacement fitted over it.
Thanks for all ur replys i got thewater out of the pannel. liked the reply about the gold fish may try it in the futhure! :lol:
Many thanks Gerard
There must be some sort of drain holes I would have thought in the panel to let any moisture out and also to let the panel breath, maybe the previous owner gave the panel a good dose of waxoil to protect it and the wax has run to the bottom with the summer heat and solidified blocking the drain holes
