54 D4D Oil Leak - Oli Pump?
greengiant
leak by side of engine - not a drop while running - soon as turn off engine starts to drip - garage first said it was cam shaft seal - replaced still leaking - replaced crank shaft seal - still leaking - now want to replace oil pump - any ideas please
Hi Maj and welcome the TOC. you will get the advie you need if you post your question on the Avensis forum.
