Hi
I have 98 corolla with 4afe engine. I would like to change injectors to slightly larger. I measured that stock injectors are about 175cc/min and I would like to change them to 190cc…220cc.
Can I take injectors from 3sfe or 7afe? 3sfe 87-91 Camry ones are probably easy and cheap to get but will they fit and work? Or do I need newer ones? 7afe has couple of different versions how do I now witch do work? 4AGE has too large injectors for my need or? Any other engine I can get injectors from?
Interested to see what the results are if you change them ;)
  • 8 years later...
Does 4zz injectors and the cams fit in a 4afe??
  • 1 year later...
Has anyone tried 1mzfe? Piggy back with Apexi safc?
