Egr Gasket Avensis 1Cd-Ftv 2.0 Diesel 85Kw
gallier
hello,
can i re-use gasket of EGR?
best regards,
hello,
best regards,
Yes you can reuse it and being steel it should be ok but it's always best to fit a new one, they are usually available off the shelf at Toyota dealers.
Regards Pete.
i've cleaned mine 3 times and never changed it!
Is there anyway of disconnecting or blanking off the egr or does it just throw a cel?
I've blanked mine offand it does still bring up a eml with code P0400 egr valve every couple of days.
But luckily I have a scan gauge permanently connected so it simply as case of a few button presses to erase the code
Car is far more willing and flexible to drive and returned me today 59.6 MPG on a drive back from the coast.
Where exactly is the egr valve on this model? I've meant to have a look at cleaning it, but got lazy. If I had a pic, with a big red circle on it... :)
