hey,
name is Hussein from Kenya have a ipsum year 2000 3s Fe. it over heats I even removed the thermostat cleaned the radiator twice made sure there was no leakage on the radiator but it still over heats. there is a sound where the timing belt is its like a bearing is faulty could this
be the problem? and the water pump is ok it pumps well. the fans are ok ...any ideas?? otherwise the car is powerful. just the heating is worrying me
  • 5 months later...
hey,
have cooling system bleeded first;
check aslo with coolant expansion tank -- whether there are no signs of en oil (gasket issue);
check with thermostatic valve;
is radiator clean from both sides?
is ventilator switched on at fixed impulse temperature of the coolant?
regards
