Front Seats
IS THEIR ANYWAY TO MAKE UR SEATS RECLINE FURTHER BACK DOWN OR IS IT ALREADY DOWN AS FAR AS IT CAN GO DOWN
There should be levers on the side for making it go up and down, then another for making the back support recline.
You might want to turn the CAPS off as this can be classed as SHOUTING.
Fish
Best post a picture of what your seats are and how low they go.
Very difficult to answer without seeing your seats.
How far down are yours reclinded,
when the seats are fully forward and the seat base raised before recling the seat back?
Is this both your Passenger seat & drivers seat that you want to recline lower, & why?
Are you reclining them when the rear seats are in place or when using the rear as carrying space,
have you tried raising the rear seat base, when reclining the front seat?
george
Looking at the seats there is a semi circular ratchet arrangement. If you were to remove the inhibitor which govens the distance of travel. You would get to the point of no returm. When the seats are fully back they are on the last notch of the ratchet and if the inhibitor was cut off the seat would just 'flop' to the rear seats with no adjustments
David
