Stereo / Nav Display
AGL
Finally got my hands on a 2010 TSpirit!
First question - how do you sort out the display on the stereo? It seems to either only show the map all the time, or the settings screen. If you select HDD or Audio, it will show them for about 45 secnds then go back to the map.
Press the "SETUP" button, select "General" then turn "Auto screen change" off.
Thanks, Kithmo.
Found it after a longer play yesterday evening before thedrive home.
Averaging 58mpg at the minute and need to check the tyre pressures. I'm sure the three different brands of tyre can't be helping, and i'm sure at least one of themisn't LRR.
