Hello
I was looking to install a second cig socket with a perminant Battery on for charging my phones over night if needed, Fused from off the Battery but can not find a way to get even a thin wire through the bulk head in to the cab if you know a way through pleases let me know with out drilling holes that is
John
Hi John
Craig has breached the bulkhead. If you oprn the bonnet and take a look behind the engine there is a large rubber grommet with a large bunch of cables going through. To the right is a a spare prodruding rubber stub. Simply cut the top off and fit your wires and cable tie it closed
David
