Plastic Clutch Push Rod?
Abi Fell
My 2007 1.3 Yaris Zinc has recently started objecting when I try to select a gear (mainly 2nd), although it doesn't seem as bad when it warms up. It feels like the pedal needs to be pushed further to work properly, even when it's fully depressed. I've read that this could be overcome by adjusting the push rod, but all the info I've found shows a metal push rod and mine is plastic. Any advice?
