Maintenance - 4.3 Replacing Rear Shock Absorbers
shcm
With reference to the excellent original post by schm on fitting rear shock absorbers. Before finally tightening the bottom and top bolts the spring on the relevant shock absorber should be loaded ,equivalent to its position if the car was on its wheels unladen on level ground. This is easily done if you have access to a ramp or pit where the car can be on its wheels or you are agile enough to access the bolts while the car is on the ground. This prevents the rubber bushes being tensioned incorrectly and failing prematurely .
  • 2 years later...
