No Power At 2000 Rpm
Cathl27
Hi guys
I've an intermittent fault where I loose power at about 2000rpm, it starts chugging for want of a better expression then it kicks in.
What can it be and how much will it cost to fix???
I drive to Cornwall on Saturday and need to get it sorted!!
Many Thanks
Cat x
Good chance it could be the EGR valve playing up...but that's just a guess.
Hi guys
Many Thanks
Cat x
petrol or diesel ?
Its a diesal, and serviced two months ago.
x
Hi guys
Many Thanks
Cat x
ok Cat
when you say "serviced" you must to have works list done.
check with EGR as easy to inspect having opened its lid. Besides -- what is condition of fuel filter?
regards / Igor
Check maf sensor too.when did this problem start?after service had been done.check fuel filter hoses/pipes to make sure they are on right and tight.
Check egr valve
