Passenger Window Banging When Going Up
Hustler1968
Hi all...
I was wondering if anyone could help me with a problem that im having with my Auris...
If I press the button (Either Driver or passenger side) down to lower the passenger window everything is fine..
However when i then go to raise the window up, at halfway theres a bang (P.S I do stop it myself on the way up, it doesnt lock and then start) and then another bang as the window reaches the very top..
has anyone any ideas on what this problem could be???
Heres a link to a small video I made of the banging sounds..
http://www.youtube.com/watch?v=1Q5jOod3THQ&feature=youtu.be
On the video you will see as im putting the window back up and as i stop it half way thats the bang and then when it reaches the very top..
Thanks guys and I hope someone can help...
P.S If anyone needs a better quality video then i can break out the proper camcorder and take a snippet if need be...
Best wishes guys and gals..
Problem sorted....
I took the panel off and there were 2 bolts hanging out of the regulator...
tightened them back up and all hunky dorey....
