Genuine Toyota Coolant Diluted
PuervesGrundy
The story is, I lent my car to my brother earlier on and it ran low on coolant while he was driving. A few months ago, I had the system flushed and genuine new stuff put in from the dealer. Today he topped it up with distilled water and I am concerned that this has diluted the coolant, which is a pre-mixed solution.
What I am wondering now is if I will have to flush the system and put totally new stuff in again?
Regards,
PG
I wouldn't worry.
The working fluid in coolant is basically water anyway; The coolant fluid provides corrosion inhibitors and stuff but unless you live in a REALLY cold country then diluting the coolant will not cause any problems.
It'll be fine until the next service I'm sure.
OK, thanks for that.
There appears to be a leak in the system at the hose leading from the engine. I presume a new clip is needed or something along those lines.
Could well be!
My old Fiesta had a terminally leaky coolant pipe; Was clipped on with some pathetic spring-clip that must have lost some of its springiness.
Pushed it further up (And lost some coolant!) and whacked on a jubilee clip for a tighter fit; That stopped it leaking! :D
When the level has dropped again, you say there's a leak, so it will, just add some undiluted antifreeze/inhibitor. Use Toyota's own assuming that's what the dealer used when the system was flushed.
It was about three litres of this stuff used the last time it was changed: http://www.ebay.co.uk/itm/GENUINE-TOYOTA-RED-COOLANT-ANTIFREEZE-1-L-PRE-MIXED-/251056004200?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3a741a9c68
Well the best solution is to stop the leak of course ;)
