been getting the abs and vsc light coming on at start-up for a week now, I did the diag test between pins 4 and 13 with a link wire and I get code 35.
Is this the front RH speed sensor before I strip things apart?
It's a 1.8 vvti 2005 corolla buy the way.
Thanks for any help
Dave P
Found it, just for info...
Code 35 - Foreign Object Attached on Tip of Front Speed Sensor RH
Cleaned the sensor and connector plug, now all ok
Code 36 is the Front LH BTW.
Dipster
