Fog Light Needed For 52 Reg Yaris T-Sport
davidg
Hi
Water has leaked into my fog light and corroded the shiny metallic coating, it looks a mess and it's about time I did something about it.
So where can I get a replacement? Fitting it isn't a problem I just need to order the part.
See pic attached - it's the driver side.
Cheers
Dave
post-48045-0-00793700-1338310226_thumb.j
  • 3 months later...
Hi
Not sure if you have managed to sort this but I have the same issue on mine.
Did you manage to find one? The best I have found is on a website called Car Parts 4 Less at £29.94 (I put in my reg. no. so hopefully it is the correct one).
Are these easy to fit as that is the next issue I will have once I have sourced one? If you have managed to sort it, any tips would be handy.
Thanks.
