Engine Serial Number
mzb
Can you also give me an idea where I can find the engine serial number too. Thanks again
Hello again, I'm sure someone will come along and tell you where to look on the engine block but you will find it in the car log book, this should be correct if the engine is the original one.
Pete.
]Hello again, I'm sure someone will come along and tell you where to look on the engine block but you will find it in the car log book, this should be correct if the engine is the original one.
Pete.
Or if someone remembered to get it changed with the dvla when the engine was changed.
But as for phsyically cant tell you where on the engine block it is.
How come you need to check?
