Front Windscreen Washer Pump - Not Working
Front windscreen washer not working
Checked the fuse but its ok and its common to the front wipers which are ok so it rules that out
Rear washer is working and I can hear the pump running for the rear windows
Not a sound out of the pump for the front when I pull the lever
Obvoiusly it has 2 pumps connected to the same washer bottle so I'm guessing the pump has failed
Has anyone replaced one of these and what is the easiest way to access to the pump?
I'm thinking the front right wheel has to come off and the wheel arch liner and I could be in there?
p.s Car is a '05 Verso 2.0D4D
