Lift Bolts, Where? How?
Simon Williams_42232
I need to replace the lift bolts on my celica vvtli but where can I get some? And what's the best way to replace them?
I've seen a few different guides and one the very straight forward, remove the rocker and replace bolts. Another is going on about rolling the car in 6th and lining things up. And then there's the official Toyota tsb or whatever it's called.
Any help is much appreciated, thanks.
Get them from Toyota. As for replacing them, it's just a case of removing the rocker cover etc, so use that guide.
That guide is right. You won't need a new rocker cover.
I take it lift isn't working at the moment.
It's intermittent, so I'm sure it's lift bolts. Any how, today I ordered new lift bolt, o ring and rocker gasket. Thought probably best to get all that new, and only cost a tenner. So I'll get on with changing all that next weekend, just Hope the bolts are worn and haven't snapped.
