Does anyone know how to remove the door card?
There are 3 plastic screws (and 2 proper screws), twist 90 degrees and pull
Where are they located?
Raistlin - do you have access to the same diagram but for the new Aygo Fire 3-door, please? I need to remove my door cards to have a look at the possibility of changing the door Speakers (though I haven't got the car yet, still awaiting delivery).
Hi. Hope this link works.
Positions at bottom.
Ian.
Sorry to bump this but I still can't seem to get my door panel off. I have a new 3-door Fire with electric windows, can only find a single screw where the door pull lever is, have popped out the studs around the edge but it appears to be stuck fast where the silver grab handle is that you use to close the door with. Are there 2 screws hidden behind this? If so how do I get to them because I haven't figured it out yet... :huh:
Referring to the above diagrams, It looks like there's a cover to remove, adjacent to the door handle, in order gain access to two further screws behind.
Yeah, I gathered that from the diagrams too, but the cover is the handle you pull on to close the door so it's got to be fairly solidly fixed in. I've tried pulling on it but it won't budge so I wondered if there was a technique to getting it off because I don't want to break a one day old car :unsure:
If you're unsure go to your dealer and get one of the tech's to give advice so you don't frack your new car :thumbsup:
True, but surely someone has done this already? I can't be the first...
I am a mechanic myself and recently too the door card off my daughters Aygo as someone had a go at breaking into it and damaged the door lock.
Removing the card on an Aygo is basic stuff as far as door cards are concerned.
It's harder to explain how to remove it than actually doing it in practice.
Seeing as it's top secret information, I'll go figure it myself ;) :D
It's not top secret information i could explain better over the phone and gladly help you out if you would like that.
Thank you for the offer, but it's only the 'pull handle' I'm curious about. If it's a simple, basic operation to pull this out (maybe in a certain way) then sharing it on this forum will help other people as well. Once I get time between the rain showers to have a go myself I'll post what I've found in a 'how to' if other people are interested :)
